Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
How to design Overlap Gate in Moldflow Insight
5 REPLIES 5
birajlahkar
1286 Views, 5 Replies
Can anyone guide me to design Overlap Gate in Moldflow Insight. Is it possible to design? Why I asked because overlapping is not allowed in moldflow.
Please have a look at attached image for an example.
5 REPLIES 5
in reply to: birajlahkar
Overlapping is not allow in Moldflow because by it's definition it is two volumes on top of eachother.  In reality, you do not have two volumes overlapping.  So you just need to create a model that contains the correct volume for both the runner and part.
Are you modeling for 3d, dual domain, or midplane?
Tim
birajlahkar
Thanks a lot, Tim!
I am modeling for Dual Domain.
Please drop some resolution. Can I design edge gate instead of Overlap gate?
Regards
Lahkar
If it were me, I would model the gate in the dual domain mesh up to the full round runner.  That would make the gate to part interface more clear in the mesh.
You could change to an edge gate if it's allowable by the part.  Unless you just want to model it as an edge gate to make it easier to model.  If so, you can certainly do that and your results should be very close for the part as a whole.  But if you're looking specifically at shear at the gate, it might be off a bit there.  It's possible that could affect your pressure numbers a bit if it's a shear sensitive material.
I hope this helps more than confuses.
Tim
raalteh
Tim is correct that two volumes should not overlap in Moldflow, but I believe what you intend to do is not really have two entities overlap, but more account for the actual shape and size and shape of the gate. If you model the part and gate (and runner in 3D CAD), you can simulate what you want with the Insight 3D solution if you mesh part and gate (and possibly the runner system) in 3D). Using a beam gate or Dual Domain would not be a good solution.
Hanno
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
Hi Iahkar,
I never use overlap gate, not in my study at least.
If you are modeling the cold runner with beams, and you don't have to evaluate so accurately what is happening at the gate (but just pressure drop and shear rate) you can use edge gate.
I've found results very similar.
