I am unable to see check-"Deflection. Differential shrinkage: Deflection" under the Warp result. could you advice how to add that.
Thank you in advance,
Abhijeet Hoshing
Solved by inba.oneway777. Go to Solution.
Hi Abhijeet,
Please do the below setup,
Process setting wizard => Warpage setting (Page2)
Uncheck the "Use mesh aggregation and 2nd -order tetrahedral elements
Run the analysis. finally you will get the differential shrinkage results in the warpage.
