I have a 3D analysis, but this does not have 'Mold internal temperature result' plot as default neither it is available in 'Create New plot'.
Does anyone have a idea about it?
Solved by mayur_dhumal. Go to Solution.
You have to make a moldblock boundary. then only you will get the internal mold temperature results.
Goto Geometry=>Moldsurface=>Moldsurface wizard will open and you have to size the mold outer surface.
After that you have to choose the Mold internal surface in cool solver paramerter settings.
Leave the Grid in default settings. if you want to change the grid location use cutting plane or section.
i hope i answered your question.
Inba
Hi Mayur,
No need togo for Cool(FEM). Norema cool analysis you will get it.
Inba
check the following
1) Create a mold boundary is must
2) In Advanced solver setting for cool. select check box ' 'Calculate internal mold temperature' & set grid resolution value.
3) It is available for Cool ( BEM) method only, not for Cool (FEM)
4) Expected result is not available by default, you need to create custom plot.
If not solved your requirement . do let us know...
