Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Hot Runner Export
2 REPLIES 2
eknema1
670 Views, 2 Replies
Hot Runner Export
Is there a way to export a hot runner as something other than a .mfr, .zip, .h3d, .udm, .stl, .pat, .mfl, .amm or .igs file?  Preferably some sort of CAD format and apparently Iges doesn't work for hot runner beams (at least I haven't got it to work).  I am trying to communicate to our suppliers exactly what we would like built.  I wasn't sure if there is a module from Autodesk or a procedure to do this.  Thanks in advance.
2 REPLIES 2
nordhb
in reply to: eknema1
the hot runners are beam elements,  1D element (2 nodes) with a property, that is displayed. (same for all types of channels: runners and cooling circuits)
So not a geometry surface, and therefore surface export not available.
The beam geometries are exported from Synergy as lines in IGES format (IGES Entity 126 Rational B-Spline Curve).
Berndt
Berndt Nordh
madhukeshwart
We can export as a IGES curves and those can be added to exisiting iges model
Then 3d feedsystem can be created as specified dimensions of beam and can be used for tool design.
Madhukeshwar T
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
