Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Gate location analysis failed
1 REPLY 1
799 Views, 1 Reply
Hi!
I tried running a gate location analysis in Moldflow 2014, but it failed with no reason. I check the log (attached image) and it only says:
C,
i
I tried running it in Moldflow 2012 and it makes the analysis correctly. What could the problem be?
Thanks for your support
1 REPLY 1
nordhb
just spotted this, a bit late reply and maybe you already got this sorted out?
Anyway,
only getting the "C" in log file means you are trying to run simulation locally, but the Insight solvers are not installed.
Install Autodesk Simulation Moldflow Insight 2014 solvers on your machine, and it should run.
Berndt
Berndt Nordh
