Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Gate Freeze time
4 REPLIES 4
klp2kor
1126 Views, 4 Replies
Gate Freeze time
Can someone tell me the best way to find the gate freeze time in a 3D Fill+Pack analysis (both hot and cold gate).
and how this time varies after considering the cool analysis.
regards,
klp
4 REPLIES 4
amwafwcel1
in reply to: klp2kor
you can get the information from the "Time to reach ejection temperature"or "Average volumetric shrinkage",but i would rather using the second one!
raalteh
in reply to: amwafwcel1
On the shopfloor they determine the gate freeze time by checking the part weight over time. When the part weight no longer chagnes, the gate is considered to be frozen.
One new addition to the 2014 release is a new xy plot that shows the part weight over time, which mirrors the shopfloor practice.
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
klp2kor
Thanks for your response.
Could you please describe me how to find the gate freeze time using "Average Volumetric shrinkage " ?
KL
Mit freundlichen Gr??en / Best regards
Prasanna K L
ED/MFE21
Tel. +49(7223)82-1067
Fax +49(711)811503-1067
BeQIK
madhukeshwart
Best way to get gate freeze time with 3D analysis is use 'Temperature result (3D)'
& Use a single contour set at the transition temperature to determine when the gate has frozen
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
