if someone is using a short glass fiber material, should he put in the "Initial Length" box (in the Filler Properties tab), the average length of the fiber or the original one ? Does AMI understand the fiber breakage in the feeding zones or should one give the final length of the fiber, therefore the aspect ratio (diameter is known).
thanks.
