hello ,
i have some doub't about fill time, i am using Tritan ex401 material ,actually i given input 2 sec for fill time but the result i got is 4 sec. if i give 1 sec the result is 2 sec, if i give any value the result is almost double... i don't know why it is coming like this?
please anyone explain ?
Hi Prabu,
first thought that comes to my mind, is that your melt front is having some flow restrictions in the cavity.
Check if there are some thin sections that may create heavy flow hesitation effects in your part. (assuming, the number of gates are the optimal ones; that they are strategically located; that you are using material's recommended temperatures; that your mesh is acceptable, etc.)
Good luck!
Hugo Herrera
