Discussion Groups
Simulation Moldflow Insight
Valued Contributor
0 Kudos
fiber orientation
212 Views, 2 Replies
09-10-2013 09:48 PM
                i have done fiber orientation analysis i got a result also, but i don't know how to read the fiber orientation tensor resut? i can't understand the result? please anyone explain about fiber orientation
Valued Contributor
0 Kudos
Re: fiber orientation
09-11-2013 04:19 AM in reply to: prabu27
in that result it shows normalized wall thickness 1 .. it indicates what? i cant understand thatone?
Product Support
5 Kudos
09-11-2013 07:00 AM in reply to: prabu27
The fiber orientation tensor result shows the degree of fiber orientation at the end of the molding process. It is depicting the probability of the fiber being oriented/aligned to the specified direction (value close to 1 means higher probability of the fiber to be aligned to the initial direction).
A more detailed explanation, along with suggestions to how to make viewing the plot easier, can be found in ASMI help files:
ASMI Help > User's Guide > Results > Fiber Orientation analysis results
Hope this helps!
-Kristen
Kristen Kilroy
