i have done fiber orientation analysis i got a result also, but i don't know how to read the fiber orientation tensor resut? i can't understand the result? please anyone explain about fiber orientation
The fiber orientation tensor result shows the degree of fiber orientation at the end of the molding process. It is depicting the probability of the fiber being oriented/aligned to the specified direction (value close to 1 means higher probability of the fiber to be aligned to the initial direction).
A more detailed explanation, along with suggestions to how to make viewing the plot easier, can be found in ASMI help files:
ASMI Help > User's Guide > Results > Fiber Orientation analysis results
Hope this helps!
-Kristen
