Is it possible to export fiber orientation tensor results to Ansys or to any other software? So far, I've tried using the "mpi2ans" command, but that only exports the mechanical properties and creates a .db file that can be used in Ansys.
Ultimately, what I would like to do is calculate the thermal conductivity based on the fiber orientation, much like what is done internally in Moldflow for the elastic modulus. Is there any way to do this internally in moldflow?
The orientation tensor plot can be exported to .xml or .nod files, but those files don't seem to contain any information relating the tensor to its location, it only relates the tensor values to the node ID number.
Any thoughts will be greatly appreciated,
Juan G Cevallos
