Hello all,
I have the necessity to run at a customer's, who is running an older version of Moldflow, an analysis with a material recently included in Moldflow Public Database. I have the latest release and can select this material. Is there a possibility to extract/export the UDB of such material so that I can bring this to the customer? Should I look in a particular folder of the hard drive?
Thank you in advance for any clarificating answer!
Hello Carlo,
if I've understood well your request, exporting of UDB file is very easy.
Now I try to explain:
1. In EDIT create new udb file with a new name (ex. the name of the material you need to export)
2. Select category: material and proprierties: for example thermplastic material
3. Click on database and search the material you want to export
4. Copy the material above
If it's not enough clear ask again, and if you are italian and if you want, send me your phone number, we can speak by phone, I'm italian too.
Alessandro
Thank you very much Alessandro!
This is exactly what I was looking for... indeed it was simple but I couldn't find it without your help!
Comunque sì, sono italiano... zona Bergamo!
Ciao e grazie ancora!
