Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
exporting deformed geometry for FEA
1 REPLY 1
benalain13
1164 Views, 1 Reply
I would like to know if anyone could help us in exporting a deformed (after shrink) geometry from Insight to be used in a FEA package.
We used with STL format but the results is very poor..
Thanks for helping
1 REPLY 1
nordhb
in reply to: benalain13
you can export a warped shape.
To export to other formats than STL or udm, it needs to be done in two steps:
1)
check the Deflection results
tab Results, Export and Publish > Warp Shape
or upper left "S" and Export > Warpage/Mesh geometry.
Now, you can export to stl format or model file.
As going to other CAE system, select Model File, Direction: Actual, and Scale Factor: 1.
The warped mesh is saved in binary udm format.
(Not sure this can be used and imported by receiving system.)
2)
Import the exported udm file to Synergy and save it.
Then to export select: Upper left "S" and Export > Model.
Then select to export in patran, ascii udm, mfl or unv format:
Patran format should be accepted by receiving system.
Hope this helps.
Berndt
Berndt Nordh
