I'm looking for a way to export warped geometry from Moldflow.
That is usually easy.
But I want to export only the X and Y deformations without the Z-direction.
Is that possible?
Best regards
Harald
Hi Harald,
If i understood your question right, under warp results we get :
If you right click on individual component (For Ex: X component), you will get drop down where you select " Mark for export" and then follow step 3 - 6 in below mentioned procedure:
You can create a results file to view in Autodesk Simulation Moldflow Communicator when you export the results in Moldflow Results file (*.mfr) format.
Hello Dinesh,
actually I´m trying to export an STL file without Z-deformation (I do have reasons for that, I just can't share these here).
So for me it seems, that this is not possible now. I would like to see that as a feature, but maybe there is a way via script?
Thanks for lloking into that issue Dinesh.
Harald
Right now we can export a warped model which includes X,Y & Z deflection
1. If you would like use the same for comparison of scanned production sample with moldflow results,use option -Actual.
2. If you would like use the same for wap compensated tool impression creation use option -Opposite.
If you have any other special requirement, please post the request in 'Simulation Moldflow IdeaStation' with genuine reason and use.
http://forums.autodesk.com/t5/ideas/v2/ideaexchangepage/blog-id/91/tab/most-recent
If your idea get more 'kudos', It may be implemented in upcoming releases
