I tried to export a Moldflow result model to Ansys (deformed piece with fibers orientation). I get the following warning in output:
** *Warning 3003005 ** Switching to principal directions in material data passing
This is due to ANSYS limits the number of TBDATA to 100000
When I import the exported model in Ansys, I get only nodes.
Any suggestion?
Thanks in advance
Pino
Ps: my final goal is to import the model in NX6 FEM or I-Deas 12 and I thought I can pass through Ansys . Is this the best way to do it? Should I use other export options?
