Hi!
I had a questition.
I run a simulation (cool-fill+pack-warpage) and i want to export the deformated geomerty? Is this possilbe with AMI 2013?
I need the deformated geomerty for further simulation in Hypermesh.
Kind regards
Günter
Solved by nordhb. Go to Solution.
you can export a warped shape.
To export to other formats than STL or udm, it needs to be done in two steps:
1)
check the Deflection results
tab Results, Export and Publish > Warp Shape
or upper left "S" and Export > Warpage/Mesh geometry.
Now, you can export to stl format or model file.
As going to other CAE system, select Model File, Direction: Actual, and Scale Factor: 1.
The warped mesh is saved in binary udm format.
(Not sure this can be used and imported by receiving system.)
2)
Import the exported udm file to Synergy and save it.
Then to export select: Upper left "S" and Export >Model.
Then select to export in patran, ascii udm or mfl format:
Patran format should be accpeted by receiving system.
Hope this helps.
Berndt
