Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Export defomated geometry
2 REPLIES 2
GünterHerz4238
475 Views, 2 Replies
Hi!
I had a questition.
I run a simulation (cool-fill+pack-warpage) and i want to export the deformated geomerty?  Is this possilbe with AMI 2013?
I need the deformated geomerty for further simulation in Hypermesh.
Kind regards
Günter
2 REPLIES 2
nordhb
in reply to: GünterHerz4238
you can export a warped shape.
To export to other formats than STL or udm, it needs to be done in two steps:
1)
check the Deflection results
tab Results, Export and Publish > Warp Shape
or upper left "S" and Export > Warpage/Mesh geometry.
Now, you can export to stl format or model file.
As going to other CAE system, select Model File, Direction: Actual, and Scale Factor: 1.
The warped mesh is saved in binary udm format.
(Not sure this can be used and imported by receiving system.)
2)
Import the exported udm file to Synergy and save it.
Then to export select: Upper left "S" and Export >Model.
Then select to export in patran, ascii udm or mfl format:
Patran format should be accpeted by receiving system.
Hope this helps.
Berndt
Berndt Nordh
GünterHerz4238
in reply to: nordhb
Hi!
Thank you.
I use the Classic UI and finally i found it.
Spoiler
Thx
Regards
Günter
