Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
nilza.reis
232 Views, 1 Reply
Error
Study: Cool (FEM) +Fill+Pack +Warp
3D Mesh
Cool – ok
Fill – ok
Pack – ok
Warp - ERROR IN SEARCH FOR SPARSE ADDRESS
STOP STOP
 STOP
What's up?
1 REPLY 1
raalteh
in reply to: nilza.reis
That looks like a bug. If the problem can be repeated, pleas share the model with the support team or provide the model here. A developer should be able to debug this and improve the code, and possibly provide a work around. We would really appreciate your help with this.
A few shots in the dark, but something to try/look at:
1) can you check the disk space available for your temporary folder?
2) if mesh aggregation is used in 3D Warp, turn it off (or in case it was turned off, turn mesh aggregation ON), This might would create a different 'matrix' that would have to be solved, which .. might avoid the issue.
3) Did the flow give a short shot? If so ... try to get a fully filled part.
4) last resort: go a global merge of the nodes with a merge tolerance of '0'00000001. This will probably not merge any nodes, but triggers a node renumbering. In case the original mesh has low node numbers as well as one or few extremely high node numbers in the model (e.g. 10000003403002), I could see this potentially some issues.
Hanno
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
