Whenever I try to play a Macro recording (.vbs file) frequently I used to get a message. (Image of the error message attached). Any help?
Thanks in advance!
Hello Biraj,
I guess this happens when there is a mistake in the script or command line.
I also got a similar error when there is mismatch of the value in the command line
But it works fine if we can correct the mistakes in the command line.
If possible share the command or vbs script file that creates error.
Regards
PK
Hi PK,
Thanks for prompting.
But I can't share it in public. If you don't mind can you share some tips and cognitive process concerning Macro?
Thanks again
