Hi Support,
We have an academic license for Moldflow Insight Adviser 2012.
When we run a cool analysis we get this error report(original file also attached):
Copyright Autodesk, Inc. All rights reserved.
(C)2009 2010 2011
Portions of this software are covered by U.S. Patent Numbers 5,287,408 and 6,096,088.
Molding Window Analysis
Version: ami2012-barium_main_ml_sp1 (Build 11221-002)
64-bit build
Analysis running on host: PC-V1403-TESTPC
Operating System: Windows 7 Service Pack 1
Processor type: GenuineIntel Intel64 Family 6 Model 23 Stepping 10 ~2992 MHz
Number of Processors: 2
Total Physical Memory: 3931 MBytes
Analysis commenced at Thu Mar 01 13:27:26 2012
** ERROR 99998 ** Required license for AMI_BASIC is not available, or all licenses are
currently in use or the product you have installed is not licensed to
run this feature.
As I can see from a previous report http://forums.autodesk.com/t5/Autodesk-Moldflow-Insight/cool-analysis-is-failed/m-p/3286477#M2172
It’s a license related problem.
But the error we get is related to an AMI_BASIC License and not an AMI_PERFORMANCE license.
I assumed that our Academic license the AMI_BASIC feature already had. If is not the case, how can we solve this problem?
With kind regards,
Matias Irizar
Groep T Leuven Hogeschool ICT Helpdesk
T +32(0)16 30 10 50
W https://mijn.groept.be/mijn/ict-helpdesk/
I will contact you directly, as need some more pieces of information.
Berndt
Hi Berndt Nordh,
We got the same issue and we are using Autodesk Moldflow Advance insight 2012 for educational. Also, we don't get the mold doctor license to work. Are we supposed to get all license of moldlfow when we purchase moldflow advance insight? Also, we purchased the moldflow synergy as well.
Since we are still under the subscription, how can we get the newer version 2013? is it automatically being delivered to our address?
cheers,
Muslimin
Hi Muslimin,
I will contact you directly, as I need some more information.
Berndt
this is replied to at:
Berndt
I've been having an issue with a Moldflow install, but getting AMI_STANDARD error in the Analysis log.
Any advise would be helpful.
Jeremy Brooks
Hi there i am having the same issue with AMA_STANDARD could sombody help me out as it is a new thing. My previous uses, for the same project, of the analysis software did not have a problem.
** ERROR 99998 ** Required license for AMA_STANDARD is not available, or all licenses are currently in use or the product you have installed is not licensed to run this feature.
Can be related to product key used when installed.
Current product keys can be found at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18678548&linkID=13030537
Is your machine client and server?
If Windows 7, make sure your LICPATH.LIC holds the localhost IP-address 127.0.0.1.
Can be found in folder such as:
C:\Program Files\Autodesk\Simulation Moldflow Adviser 2014
Hope this helps.
Berndt
