Elastollan 1154D is in the material database of Autodesk Simulation Moldflow Synergy 2013, SP2, where you can find the materials properties requested.
Melt mass flow rate (MFR) might not necessarily be a property available, as provided by material supplier.
Elastollan R2000 is currently not in the material database.
What you can do:
- Look up data at material supplier site
- Contact the material supplier and ask for an udb-file for the material, and/or other material properties. The udb-can be used to view material properties.
- Contact the material supplier and ask for an equivalent udb-file for the material, or to use an equivalent material data from the material database.
- If you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com and get measured data fitted and an udb-file for analysis in return. (material supplier might have measured data of this material?)
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Hope this helps.
Berndt
Berndt Nordh
