Hi all,
Can we extract DD mesh/ mesh along the surface of the part, from a part which is has been already meshed with 3D mesh type ?
Solved by madhukeshwart. Go to Solution.
It is same as you converted DD mesh to 3D.
Change mesh type DD, Then generate mesh.... It will strip surface mesh as DD.
