Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Duplicating 3D mesh to DD
1 REPLY 1
dinesh27mec
422 Views, 1 Reply
Hi all,
Can we extract DD mesh/ mesh along the surface of the part, from a part which is has been already meshed with 3D mesh type ?
Dinesh Kumar D
1 REPLY 1
madhukeshwart
in reply to: dinesh27mec
It is same as you converted DD mesh to 3D.
Change  mesh type DD, Then generate mesh.... It will strip surface mesh as DD.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
