Hello all,
I am using Autodesk moldflow insight 2011.
Windows XP Professional x64 Service Pack 2.
I am facing display image difference between Dual domain and 3D images (normal and with result image) as shown below. some of my customers are questioning this problem.Please share your experiences.
Thanks in advance
JK
In 3D meshed parts the 'gate' has to be part of the solid 3D model that is imported to moldflow.
In 3D mesh the 'gate' cannot be build in moldflow, while runner and sprue makes no problems as you can see in the picture above.
This problem existing with mold flow since long & it is expected to be fixed with every time
they release a new version. At least we expect it should be fixed in next service packs.
Even though it will calculates properly, but some time we feel difficult to convince the end user.
This visualization bug should be fixed at the earliest
This issue seems to be fixed with latest Version of Synergy.
You can close this Issue as accepted.
Mayur
The display issue has been identified and should be availble in the next release.
As Tim mentioned in his response, the solver calculates it correctly, but the user interface had a problem.
It has been pending since long. Moldflow team should have taken on priority.
