Hi everybody
I have done a warpage analyse and maximum warpage was 2.5 mm . But when I defined mold surface , warpage changed to 0.2 mm in opposit direction ! . I m confused should i define mold surface area for warpage and is it necessary for warpage analyse or not ?
With Best Regards
description is a bit short and more information is needed to understand this specific issue.
Generally: With mold surface modeled, it is assumed cooling circuits and cooling analysis has been done.
When adding cooling, this can affect final shape.
The magnitude change mentioned can be realistic, and depends on part design, material, cooling circuits layout, process settings and so on.
Initially one run analysis and compare warpage trends to find what performs best.
Then add cooling to analyze if the trend is the same or changes.
To understand what affects warpage, what contributes most to deflection result, you could also run analysis with option "isolate cause of warpage".
To compare analysis when a model change, the use of Anchor plane is a good way.
This is found at tab Results, Visualize. One use 3 nodes for creating the Anchor plane.
Then same plane for comparing deflections can be used, comparing different analysis.
Have you compared surface temperatures on your initial analysis, and surface temperatures when cooling analysis?
From the magnitude mentioned, it seems as the introduction of cooling analysis, shows a temperature difference that affects the deflection result.
Berndt
