Discussion Groups
Simulation Moldflow Insight
Member
jeffmueller5430
Die-casting Simulation?
233 Views, 4 Replies
06-19-2014 04:39 PM
Does Autodesk have an application that can simulate aluminum die-casting, i.e.- similar to Autodesk Moldflow Insight for plastics?
If not, what (not-Autodesk) applications are available?
Thanks!
Please use plain text.
Employee
Alex.Bakharev
Re: Die-casting Simulation?
06-19-2014 06:41 PM in reply to: jeffmueller5430
Autodesk does not have a specialized software for die casting.
I have heard the people achieved good results by applying Autodesk Moldflow analysis to die casting. I never tried it myself but from the general principles I would advise:
  • Prandtl numbers for metal melts are way smaller than polymer melts. So the inertia is way more important for metals than for plastics. Thus, for die casting only use 3D analysis with inertia terms swiched ON
  • Use finer meshes and bias the mesher to get finer mesh on the surface. This is to better catch to boundary layer effect.
  • While HTC for polymers molding affect flow only marginally, for the metal die casting it is much more important. Thus, select correct HTC in the Part(3D) properties. HTC for metal casting even dependent upon such things as the thickness of lubricant applied to the mold.
Member
jeffmueller5430
06-23-2014 08:29 AM in reply to: Alex.Bakharev
Alex, thanks for your reply.  It sounds creative and we might attempt it but we'd be more interested in a supported solution, even if it's not an Autodesk application.
-Jeff
Employee
Alex.Bakharev
06-23-2014 05:44 PM in reply to: jeffmueller5430
As far as I know the most popular supported solution for die casting is magmasoft.
Member
jeffmueller5430
06-24-2014 08:06 AM in reply to: Alex.Bakharev
Alex, thanks for your follow-up.
