Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Data considered in genearting volumetric shriankge plot
1 REPLY 1
madhukeshwart
283 Views, 1 Reply
Dear All,
I would Like to know,
When Moldflow flow analysis results generates volumetric shrinkage plot,
Does it purely based on PVT data of material or it does consider both moleculer oreintation
& fiber orientation data of material also ?
Thanks & Regards,
Madhukeshwar.T
Mob:- 9970195704
E-mail: madhukeshwart@gmail.com
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
1 REPLY 1
raalteh
in reply to: madhukeshwart
The volumetric shrinkage calculation is not directly influenced by the fiber orientation; remember, this is 'volumetric' shrinkage.
For a fiber filled material, the orientation of the fibers does influence how the 'volumetric shrinkage' is distributed. In the dominant fiber direciton, you will see less shinkage, than perpendicular to the fiber direction. You will see this after a warpage analysis is performed.
I hope this helps
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
