I´m currently searching for the specified above *.udb file. Normally the producer SABIC should be the right contact, but they have a change of a software system and they can not say, when they are able to provide the file to me.
Maybe there is someone out there, who already did a MFA with the specified above material and who can provide it to me. I hope so. Or maybe you can tell me, where I can get it as soon as possible.
Thanks!
Best regards
Thorsten
P.S.: Sorry for my not-so-perfect English
In Moldflow software community-> contact autodesk material lab
if you contact the autodesk lab, they help you to findout the .UDB file for the material.
Good morning,
i have the same problem with another material of Sabic, Valox EH 7020.
" if you contact the autodesk lab, they help you to findout the .UDB file for the material." Do you mean to write an email to datafittingMoldFlow@autodesk.com, or anything else?
this article can also give you some input:
Material data is missing in Moldflow material database
Hope this helps.
Berndt
Hi
Contact your material supplier's technical team (in your case ; SABIC)... they can support you in getting the UDB file
If not contact autodesk (datafittingMoldFlow@autodesk.com) I hope autodesk charge you for this service.
M P Pradeep Kumar
2. If the specified grade is OEM specific, contact SABIC through OEM. They might be owning the rights.
3. If you would like to get it done tested. Pay autodesk Datafitting team... They will test and create UDB file for you
