I have model the cooling channels with the curves to represent the cooling circuits and "V" shape curve for baffle. however, I have little bit confusing to specified the height /gap between the channel and property assign to each of curve. kindly refer to attachment for clarification requires.
Lim
Solved by harald_goetz. Go to Solution.
You may find the answer here:
There is a link to a video:
https://screencast.autodesk.com/Main/Details/3604cad2-e2ba-40f5-9832-93f36ca5b3ec
Your slide seems to be confidental somehow, at least it states so in the bottom line.
The answer can also be found in the moldflow help:
http://help.autodesk.com/view/MFIA/2014/ENU/?guid=GUID-960FD6FF-558B-49CF-A32C-99116E4593E7
The pictures are prettx clear I guess.
HTH
Harald
Hi
Hope this helps to clear your doubt
M P Pradeep Kumar
