Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Create Baffle
2 REPLIES 2
OMNI51jkc
850 Views, 2 Replies
Create Baffle
I have model the cooling channels with the curves to represent the cooling circuits and "V" shape curve for baffle. however, I have little bit confusing to specified the height /gap between the channel and property assign to each of curve. kindly refer to attachment for clarification requires.
Lim
2 REPLIES 2
harald_goetz
in reply to: OMNI51jkc
You may find the answer here:
http://knowledge.autodesk.com/support/simulation-moldflow-insight-360/troubleshooting/caas/sfdcartic...
There is a link to a video:
https://screencast.autodesk.com/Main/Details/3604cad2-e2ba-40f5-9832-93f36ca5b3ec
Your slide seems to be confidental somehow, at least it states so in the bottom line.
The answer can also be found in the moldflow help:
http://help.autodesk.com/view/MFIA/2014/ENU/?guid=GUID-960FD6FF-558B-49CF-A32C-99116E4593E7
The pictures are prettx clear I guess.
HTH
Harald
mppkumar
Hi
Hope this helps to clear your doubt
M P Pradeep Kumar
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
