I am trying to make a COOL (FEM) analysis in a project in which I have already made a Fill + Pack + Warp analysis. I have configured the cooling system and the mold block.
But when I launch the 3D mold mesh, it stucks and does not converge. I have read the log and it says this:
Copyright Autodesk, Inc. All rights reserved. (C)2009 2010 2011 2012 2013 Portions of this software are covered by U.S. Patent Numbers 5,287,408 and 6,096,088. Version: ami2014-cerium_compile_windows-x64 (Build 13213-374) 64-bit build ***** Mesh with the following settings: External mold surface edge length: 0.0000 mm Internal mold surface edge length: 0.0000 mm Target number of nodes on circumferences of cylinders: 12 Generating mold surface mesh Percent 20 done .... Percent 40 done .... Analysis aborted by user ...
I put the edge lengths to 30 and 12 mm, but in the log file they seem to be zero values and I worry if this could be the problem. I have tried several times with different values, restarted MF... but in vane.
Could this be the reason for the non convergence?
Thanx!
Solved by nordhb. Go to Solution.
this is proabaly related to a non-English operating system that uses a comma as the decimal separator.
Please, update to:
Autodesk Simulation Moldflow Synergy 2014 Service Pack 2
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22088767&linkID=13030538
Autodesk Simulation Moldflow Insight 2014 Service Pack 2 (Solvers)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22088614&linkID=13030538
To service pack 2, the 'Create Mold Block' function works as expected, when applied to a freshly meshed,
imported CAD model on a non-English operating system that uses a comma as the decimal separator.
Or another workaround: Change your locale to En-US.
Hope this helps.
Regars,
Berndt
