Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Coverge problem COOL (FEM)
3 REPLIES 3
616 Views, 3 Replies
I am trying to make a COOL (FEM) analysis in a project in which I have already made a Fill + Pack + Warp analysis. I have configured the cooling system and the mold block.
But when I launch the 3D mold mesh, it stucks and does not converge. I have read the log and it says this:
Copyright Autodesk, Inc. All rights reserved.
(C)2009 2010 2011 2012 2013
Portions of this software are covered by U.S. Patent Numbers 5,287,408 and 6,096,088.
Version: ami2014-cerium_compile_windows-x64  (Build 13213-374)
         64-bit build
Mesh with the following settings:
  External mold surface edge length:                         0.0000 mm
  Internal mold surface edge length:                         0.0000 mm
  Target number of nodes on circumferences of cylinders:    12
Generating mold surface mesh
    Percent  20 done ....
    Percent  40 done ....
Analysis aborted by user ...
I put the edge lengths to 30 and 12 mm, but in the log file they seem to be zero values and I worry if this could be the problem. I have tried several times with different values, restarted MF... but in vane.
Could this be the reason for the non convergence?
Thanx!
3 REPLIES 3
All right, I restarted my computer and now the meshing goes on! Perhaps this can be a bug in MF14??
nordhb
this is proabaly related to a non-English operating system that uses a comma as the decimal separator.
Please, update to:
Autodesk Simulation Moldflow Synergy 2014 Service Pack 2
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22088767&linkID=13030538
Autodesk Simulation Moldflow Insight 2014 Service Pack 2 (Solvers)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22088614&linkID=13030538
To service pack 2, the 'Create Mold Block' function works as expected, when applied to a freshly meshed,
imported CAD model on a non-English operating system that uses a comma as the decimal separator.
Or another workaround: Change your locale to En-US.
Hope this helps.
Regars,
Berndt
Berndt Nordh
in reply to: nordhb
I sometimes noticed a extrange behaviour when introducing comas, yes... Thank you!!
