Hi all,
I have a cooling analysis to be done with channels using oil instead water.
For this cases is applicable the same principle as the water cooling channels, that is using a temperature 10-15C lower than the mold temperature or its exactly the opposite and we should define the temperature at cooling channels higher than the mold surface temperature.
Melt temperature - 350C
Mold temperature - 150C
Cooling channels - ??
Thanks in advance,
Gui
