Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Cool FEM warning
2 REPLIES 2
879 Views, 2 Replies
Cool FEM warning
I have done an analysis in the following sequence:Cool FEM+Fill+Pack+Warp.  During Cool FEM  check, I've got a warning: "** WARNING 312075 ** Low part-mold contact ratio, the results could be inaccurate". It was proved to be true and the results did not show any transient variation of the temperature. I've modeled properly a 3D mould  and an option chosen for transient heat flux calculation was "flow analysis on every iteration". Thank in advance for any help and advice.
Tatiana
2 REPLIES 2
nordhb
it is difficult to answer this without having the study.
For some reason you have ended up with a mesh at mold-cavity interface that seems to be not good.
Maybe this video can help, about the set-up workflow:
http://wikihelp.autodesk.com/Simulation_Moldflow/enu/2013/Videos/AMI_Transient_cool_analysis_on_an_A...
For further troubleshooting of the reason the study file is needed.
Berndt
Berndt Nordh
madhukeshwart
Even if you got a warning , Low part-mold contact ratio. analysis will run. Some times,  the Cool (FEM) analysis results will not converge.
If analysis completed, in cool (FEM) results, you will a get plot, called 'Improper part-mold contact',which  will highlight  the issue area in red colot. Then remesh the mold and fix these areas.
Finally ensure that there are no areas of red, indicating no contact.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Tags (1)
