I am currently trying to run a FEM Cool analysis but it doesn't run and it doesn't show any errors in the log, it just stops.
I imported the mold as an STL file from solidworks and then assigned the mold block property and create the mold mesh. The part's modeling seems to be ok since I ran the Cool+Fill+Pack+Warp analysis without problem.
This is a 3 cavities family mold. I thought that the issue was that the number of elements was too high, so I tried to run the analysis modeling only a section of the mold (just one cavity) but the same problem came up.
The analysis stops right after showing up "Performing cycle averaged cooling analysis" in the log. I am running the analysis as conduction solver and transient within cycle. The analysis sequence is set to Cool (FEM).
I appreciate any help you can provide with this.
Gabriel Mendible
