Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Continue packing analysis after filling
8 REPLIES 8
Message 1 of 9
teopado89
863 Views, 8 Replies
Hi everyone, maybe it could be a very simple question:
i start with a filling analysis. Then when i've optimized pressures and gate location i want to run a fill+pack+warp analysis.
Usually i duplicate the filling study, i switch to the new analysis type and i run it.
Sometimes MF completes the "new" filling in 1 minute (maybe it is still in its memory) and MF jumps immediately to packing. Sometimes it run again the filling.
The question is:
how can i avoid to run again the filling and continue immediately with packing and warpage analysis? thanks
8 REPLIES 8
Message 2 of 9
inba.oneway777
in reply to: teopado89
This problem because of temporary memory stores the copied file results. Following steps to overcome this problem,
  1. Need to change the copied file name.
  2. Uncheck the log or close the log
  3. Go to mesh tap -> Properties tap -> Remove (Click to remove the unwanted properties)
  4. Do purge nodes
  5. Start the run the simulation again.
i hope it will give the solution.
Inba Sudhahar D
Mail: inba.oneway777@gmail.com
Phone: +91-9884929216
if the answer is accepted as a solution. Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 3 of 9
teopado89
in reply to: inba.oneway777
Thanks for the answer, but when i change the analysis sequence, filling results disappear
Message 4 of 9
inba.oneway777
ya, i agree with your suggestion. however i tried with this option. some time i got the same issue again.
Inba Sudhahar D
Message 5 of 9
teopado89
The problem is still open.
Please may someone help us? Thanks
Message 6 of 9
If you are performing only a Fill analysis for one study & duplicating that study to do some modifications in process or in gate location to perform a Flow+Warp analysis it will consider as a new analysis & it will start running from the Fill - Pack & Warp analysis.
But if we already ran a Fill+Pack analysis & try to duplicate the same study & do some changes only in your Packing profile (not in a fill time or Melt & Modl Temp) , warp analysis settings & perform Fill+Pack+Warp analysis, then the analysis will starts only from Pack analysis it wont perform new fill analysis for you.
In your case it will consider as a new study if you do these kind of major changes in gating locations & Processing conditions. Then analysis will starts from the filling cycle not directly to Packing,
Thank you
Regards
Sabarinathan. S
Regards
Sabarinathan. S
Core Engineering Specialist - Plastic, Auburn HIlls, USA
eMail : sabi1021@gmail.com
If U accept the solution... Give us a Kudos.... Happy Learning....Thank you! .....
Message 7 of 9
madhukeshwart
Please Note the following
1. If you are Using Midplane or Dual domain mesh. It is possible.  If you are using 3D mesh. It is not possible.
2. when you complete fill study, when you set as fill +pack ... try to duplicate the study. If not, it will delete fill results and starts from fill analysis.
3. If you change mesh or fill control, then it starts from fill.
4. Try to check setting in solver, when running analysis log should show as below
Analysis Log
5. Restart file  :
6.  Refer the following, how to set Restart
Setting restart steps
7.  Refer the following, how to use restart files to exted analysis.
If not solved your problem, Plese reply.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 8 of 9
vasyabc
in reply to: sabarinathan1021
Good one sabari
Message 9 of 9
teopado89
in reply to: madhukeshwart
Thank you madhukeshwart for the complete answer.
I tried point 7 and it works.
Maybe my mistake was this:
after running the pack analysis, i check if filling parameters were correct. Maybe Moldflow thought they were different.
