Discussion Groups
Simulation Moldflow Insight
Active Contributor
rmathan
Compare Warp Results between CRIMS and Uncorrected Residual Stress Model
260 Views, 2 Replies
01-22-2014 09:17 PM
Dear Forum,
I wanted to check the effect of CRIMS Shrinkage model used in Warp Results.
the selected material has CRIMS model
Can I use uncorrected residual stress model by editing the material properties to compare the results with CRIMS model?
Mathankumar. R
Please use plain text.
Valued Contributor
tim.vanast
Re: Compare Warp Results between CRIMS and Uncorrected Residual Stress Model
01-31-2014 06:59 AM in reply to: rmathan
Yes.  You can select the different shinkage models by editing the material.  You'll need to save the edited material file as a new file.
Tim
Active Contributor
rmathan
02-08-2014 02:40 AM in reply to: tim.vanast
Thank you Tim!
Mathankumar. R
