the first Synergy user interface you start will connect to the OLE automation client.
This means access to Command Line and Macros Record/Playback.
The second (and more) Synergy user interfaces you starts, will not have access to macros.
If you close the first Synergy user interface you started, and still have other Synergy running,
Command Line and Macros Record/Playback will not be accessible anymore - even if starting a new session of Synergy.
In this case, one have to close all Synergy interfaces that are open, and start a "first" Synergy to
connect again and get access to Command Line and Macros Record/Playback.
From my understanding this is a windows limitation.
Berndt
Berndt Nordh
