Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Command-line error: cannot open error file
2 REPLIES 2
MartinCavalry
745 Views, 2 Replies
Hi All,
I have Insight Ultimate 2013 installed and updated with SP2 on a new PC.
The problem comes when I import my study files from a previous computer (on which everything was working flawlessly).
But now, ONLY the DUAL DOMAIN mesh/analysis works and it HANGS with 3D after determining the "Total projected
area ... " in the log window (nothing happens even after 24 hrs!)
Thats the error I get every time in the log whenever I change to 3D solving:
"Command-line error: cannot open error file "C:\windows\temp\OCL_four digits.TMP.LOG"
Has anyone come across with this???
this is extremely annoying as I cannot use my old studies from my previous computer.
Please, do you have any remedies, suggestions how to solve this.
Thank you!
2 REPLIES 2
I suspect you have an ATI graphic card and probably also windows 8 ?
This is a known issue with ATI drivers, when trying to use GPU.
To workaround that problem you can either :
- Disable the GPU in the advanced options when launching an analysis
- Get right access for windows/temp directory. In Windows 8, you cando that by just using explorer to go in w:\windows\temp and follow the prompt
Hi Yannick,
thank you for your comment and sorry for my late reply.
The problem has been resolved and I can confirm that was related to the ATI graphics card...
thanks again
Martin
