Hi!
I had a questtion about the color code in the re-melt analysis.
What means the colors? (normally blue gave out nagtive value and red positive value) I found nothing about this values in the help.
Best regards
Günter
Solved by Paul.Larter. Go to Solution.
Hello Günter
The colour in the re-melt zone plot does not have any reference to a negative or positive value. This result tells you where, on the boundary between the first and second components, re-melting is likely to occur.
You can control how the re-melt zones are displayed by right clicking on the plot result in the results list and changing the plot properties, you can choose any colour you wish.
