Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
coincidence nodes
1 REPLY 1
667 Views, 1 Reply
coincidence nodes
hello,
                while running moldflow 2k overmolding analysis warning msg showathe first shot and second shot nodes are coincidence..
how to avoid this isuue
1 REPLY 1
nordhb
avoid to use Global Merge, it will merge nodes at interface, and cause co-incident nodes.
To squeeze model node numbering use Global Merge with negative tolerance such as -0.1
To fix this, copy one of the parts away, for example part B to part B1.
Remove the part B.
Translate back part B1.
Do a Global Merge with negative tolerance such as -0.1 to squeeze model node numbering.
Hope this helps.
Berndt
Berndt Nordh
