Discussion Groups
Simulation Moldflow Insight
New Member
1 Kudo
Clamp force prediction?
609 Views, 4 Replies
08-06-2013 02:52 AM
I am simulating a plastic housing of plastic wall thickness of less than 1mm (approx. 0.8).
I have some questions, should I simulate it with 3D or Dual Domain mesh?
I have doubt with clamp force. Below are attached two pictures of my part showing the injecting direction (-ve Z-axis) and the core mold direction (+ve Z-axis). There are two sliders in Y-direction. Parting line in in the Z-axis
Can you confirm that the Moldflow solver will give correct values for the clamp force with the coordinate axis that I am using?
With regards
Karmakar S.
Valued Contributor
18 Kudos
Re: Clamp force prediction?
09-20-2013 04:01 AM in reply to: KarmakarS
I think it is better to use the Dual Domain mesh for that kind of part.
To get a correct prediction of the clamp force, you just have to put the clamp force in the Z axis, as you have done.
"Maybe Moldflow does not work properly, but the real world neither."
New Member
1 Kudo
09-20-2013 04:08 AM in reply to: KarmakarS
Thank You
Regards
KarmakarS
Active Contributor
18 Kudos
Betreff: Clamp force prediction?
09-23-2013 01:06 PM in reply to: KarmakarS
Nie and funny,
I also had this part on my desk.
Distinguished Contributor
18 Kudos
09-25-2013 02:07 AM in reply to: phammer
Sharing the same feelings here, i had simulated this part last year. :smileyvery-happy :smileyvery-happy:
