Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Clamp force prediction?
4 REPLIES 4
KarmakarS
1052 Views, 4 Replies
I am simulating a plastic housing of plastic wall thickness of less than 1mm (approx. 0.8).
I have some questions, should I simulate it with 3D or Dual Domain mesh?
I have doubt with clamp force. Below are attached two pictures of my part showing the injecting direction (-ve Z-axis) and the core mold direction (+ve Z-axis). There are two sliders in Y-direction. Parting line in in the Z-axis
Can you confirm that the Moldflow solver will give correct values for the clamp force with the coordinate axis that I am using?
With regards
Karmakar S.
4 REPLIES 4
PascalGosset
in reply to: KarmakarS
I think it is better to use the Dual Domain mesh for that kind of part.
To get a correct prediction of the clamp force, you just have to put the clamp force in the Z axis, as you have done.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
KarmakarS
Thank You
Regards
KarmakarS
phammer
Nie and funny,
I also had this part on my desk.
mayur_dhumal
in reply to: phammer
Sharing the same feelings here, i had simulated this part last year. :smileyvery-happy Smiley Very Happy
