Currently we have a lot of parts which are all random oriented since in the past it never mattered. Now that we want to try to perform Injection compression simulation we have to make sure the part is oriented with the Z going perpendicular to our parting line. I have not been able to find a way to reorient the part so that we can perform this analysis. Today we are using Solidworks and with the numerous numbers of randomly referenced geometries it is impossible to simply change the original.
I have tried the "move" option in Insight 2015 however I can never select a suitable piece to perform a rotation.
Please help.
Solved by kristen.kilroy. Go to Solution.
Hello payninater,
In regards to you mentioning you tried the "move" options n Moldflow - have you used the "Rotate" option? This is the best way to rotate your models inside of Moldflow. I've listed the steps to do this below:
Alternately, you can rotate the model in your CAD program prior to importing. The technique to do this varies between CAD programs however.
I hope this helps! If not, please feel free to respond.
