Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
cannot import a part
2 REPLIES 2
NADIHATASHA
421 Views, 2 Replies
hi all
what is this mean?i cant import my part into this software
2 REPLIES 2
teopado89
in reply to: NADIHATASHA
i'll try to save the cad in stl format, and then import it in Moldflow.
nordhb
in reply to: teopado89
the geometry is probably not an enclosed volume, a solid, and/or it also holds free, not connected, surfaces.
If there are gaps or missing faces or free surfaces/faces, it is a collection of faces and quilts. A closed solid volume cannot be created.
Using STL is a workaround.
Or import surfaces via IGES.
Also, check cad geometry in cad system, or CAD Doctor, and fix/repair where needed.
Hope this helps.
Berndt
Berndt Nordh
