Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Cannot find Injection-Compression under Molding Processes
2 REPLIES 2
531 Views, 2 Replies
Hallo,
I want to run an injection compression analysis but cannot find the injection compression process at the Molding Prcess Setup. Also the Tools > Workspace > Customize Menue did no exist. Can you please help me!Using Moldflow Insight 2013
2 REPLIES 2
nordhb
the Injection Compression analysis is mesh dependent, and in ASMI 2013 it is available for mesh type Midplane.
Please, change to mesh type Midplane, and you should then be able to see molding process for Injection Compression Molding.
Berndt
Berndt Nordh
That's it!
Thanks for helping me!
