Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
automatic import of many bdf meshes in moldflow - how could this work
1 REPLY 1
phammer
412 Views, 1 Reply
Hi everybody,
I want to add some meshes to a study. Yes i can do this by hand with the add command, but I don't want to do this with mare than 20 meshes.
I was thinking of if there would be a possibility to write a script that imports bdf files in a folder to a study. Would this be possible?
Greetings Philipp
1 REPLY 1
nordhb
in reply to: phammer
this should be possible.
You need to use File System Object
Set fso = CreateObject("Scripting.FileSystemObject")
to collect files from a folder.
You can then loop through the files and use:
StudyDoc.AddFile
Here is an example:
'Creating File System Object
'Getting the Folder Object
'Only the files to be added in this folder
Set ObjFolder = fso.GetFolder("C:\Temp\add_files")
'Getting the list of Files
Set ObjFiles = ObjFolder.Files
'Getting the Path and Name of each File and Add
SetLocale("en-us")
Set Synergy = CreateObject("synergy.Synergy")
Synergy.SetUnits "Metric"
i=0
 Set ImpOpts = Synergy.ImportOptions()
 Set StudyDoc = Synergy.StudyDoc()
 'ImpOpts.MeshType "3D"
 'ImpOpts.Units "mm"
For Each ObjFile In ObjFiles
 StudyDoc.AddFile ObjFile.Path, ImpOpts, False
 i = i + 1
Next
MsgBox "Files Added: " & i ,, "Information"
 The import options are outprompted, but might need to be adjusted for your purpose.
You can copy above code to a text-file and save as vbs.
Change path or copy bdf-files to folder as in script, and give it a try.
Hope this helps.
Berndt
Berndt Nordh
