Hi all,
After I install the Moldflow synergy, I am getting the security failure even before activation/launching the software. This happens irrespective of order of installation - moldflow insight solver and synergy.
I goes like this.
A security failure has occured. Check the following -
1. You are using the correct license server.
2. You are using appropriate version of product security
etc.
Has anyone encountered such a problem before?
I followed these steps, but in vain.
Solved by zhangchar. Go to Solution.
If you haven't had a Network License Manager (NLM) installed, then you also need to install it by clicking "Install Tools & Utilities" button within either Insight or Synergy installer. You also need to get license file for both Insight and Synergy and setup NLM to use it before you can start Synergy. There is no trial version of Insight or Synergy.
Charlie
