I'm trying to simulate a higher temp 2 shot mold, and was wondering if it's possible to export the bulk temperature result from the 1st shot (at ejection time), and then assign it to the part insert body for the 2nd shot?
Right now the 1st shot is assumed to be isothermal when used as a part insert, but there are several very thin wall sections that cool much faster than the largest cross sections of the part. I could see this being an issue when it comes time to run warp and cool simulations on this model.
Jeff
Solved by madhukeshwart. Go to Solution.
Better to run the analysis as Sequential overmolded option
Madhukeshwar,
Thank you for your advice. I can run the fill, pack, and warp with the overmold simulation but I cannot run cooling to validate that my baffle and water line placements are optimized. Is there any way to integrate this with the overmold simulation?
Jeff
Yes, You are right...!!
Cool + fill+ pack + over molding fill + overmolding pack + warp is not available in moldflow.
Probably Autodesk team should develope the same.
