Hi Solymossy,
I don't know if you have found this yet (it's very useful but , but there is a pretty complete reference guide in the Help. Access the Help, then hit 'Home' on the top bar, click on "Application Programming Interface (API)', then 'API Reference' and then click on the 'Classes' tab. This has a full reference of all API calls, their variables and their meanings.
To find out what the variables ini 'WarpQueryNode' mean you access the 'Classes' tab and click 'PlotMgr' and then scroll down to the topic 'WarpQueryBegin'.You find the following below. I your variable '6250' is the small deflection warp data set (you can find this ID by looking in results.dat in "C:\Program Files\Autodesk\Moldflow Insight 2010-R2\data\dat'. This data set has only one data point per node (which why tthe IndependantValue is set to 'Nothing;. Another data set would be '6260' (non linear warpage data) which has multiple data points (ththe incremental load steps, which can be accessed by specifying which load step to access, using the Independant value.
I hope this helps
Boolean WarpQueryBegin ( long aDsID,
Object aIndpValues
Start queries on a specified warp dataset
Parameters:
aDsID data set id
aIndpValues independent variable values
Returns:
TRUE is successful
Example:
This example queries displacement values in the first anchor plane on node 100
Set Synergy = CreateObject("synergy.Synergy")
Set PlotMgr = Synergy.PlotManager()
Set queryValues = Synergy.CreateDoubleArray()
PlotMgr.WarpQueryBegin 6250, Nothing
PlotMgr.WarpQueryNode 100, 1, queryValues
PlotMgr.WarpQueryEnd
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
